I have an opportunity to buy 2 2006 RXTs with trailers for 5k from someone I know well and trust. They both have been well maintained. They were both used almost exclusively in salt water and have not been run at all in the last 2 years. They were winterized when last put away. They each have approx. 150 hours on them. The owner thinks but is not 100% sure that the ceramic SC washers have been changed. I plan to do the following;
Before starting:
Drain old fuel
change oil
pull spark plugs lube cylinders lightly and crank over with plugs still removed
start and run briefly on hose
put them in the lake for a quick wet test
pull SC to check on ceramic washers or not
Does this sound like a reasonable approach?
Do any of you guys have advice on what else I should or should not do?
I have never before owned or worked on a PWC, and the tiny bit I do know I have learned by reading here.
Thanks,
-Craig
Before starting:
Drain old fuel
change oil
Thanks,
-Craig
