P0326 - Knock sensor...been replaced 3 times
basejumper
Hi guys, new here...
My ski has had the knock sensor replaced 3 times in the last 5 years and yesterday the darn error code came up again.
Nowhere locally to me will touch jetski's, and the one place I found said 3 month wait.
I am tempted to leave the fault code there, as it hasn't affected the ski's performance at all.
Thoughts please.
Thanks in advance!
It could be the wiring to it that's the problem , check for strained or bad connections or wires. What code is it giving out?
P0326 - I checked all the wires I could see next to the battery (and battery terminals) and they all look ok. I'm going to take it out again today and see at what point exactly it occurs.
ps. no idea why the above is larger font
There specific ohms readings for the wiring harness , the connectors could be bad, even at the computer , sometimes the wire is damaged inside , if you need the sheets I can send you a copy.
Thanks for that bud, thats really helpful. I'll check today if its 5,000 RPM it comes on at, I think it is.
