SeaDooNaples
I recently purchased a 2007 GTX Limited with 45 hours on it, in like new condition. Previous owner took very good care of it, and has not used it in the last year. I've taken it out 3 times and it ran great, now up to 49 hours. The last time I took it out the low gas light came on. Today my brother wanted to use it, so he filled it with gas and it ran fine in idle. When he went to accelerate ski would not power up, engine made a loud noise and power off. It restarted easily and he was able to idle back into the marina, but not accelerate or it would shut off. It also burned through 1/2 tank of gas idling for a little over an hour. The time before it seemed to be burning more gas than usual but was running it hard 60 mph range so I did not think anything of burning more fuel. He said it was giving him P0116 and P0117 which are faulty engine temp sensor and engine temp sensor shorted to ground. Any idea what would cause this?? My brother thinks it may be an issue with needing coolant. I'm just wondering if this may be an easy fix, or if I should have a mechanic look at it.
