i'm back unfortuanteley. after repairing my beeper(thanks for the help and the radio shack beeper tip) and after installing the new stator and and making sure it was timed properly. we finally got it to crank. port engine is perfect. starboard is very hard to crank and when it does, it runs badly and won't accelerate at all. it barely runs really. this is what we've tried so far. we put in new plugs. trimmed the tips off the wires. took off the carburetor and took it apart and cleaned it. seemed clean and fine. inspected the fuel lines to make sure they are not gray(they are black except one small gray line on the carb. changed the fuel filter. unplugged the two yellow wires and plugged them into the other good engine rectifier, no change. adjusted carb every way we could think to adjust it. checked compresion 140 psi on each cylinder. what else could be the problem?
