needforspeed
Ok I need the big guns on this one...Snipe, Dr. Honda?
Ok, I have a 89 SP that has no spark. The engine is totaly rebuilt while it was apart I tested all the ignition parts as decribed by the shop manual with the multi meter (all checked out ok) Now I put the engine back in, get everything situated and I crank it over to make sure all my conections are good. I have a spark tester (it is a spark plug boot with a lightbulb in line to a post which is the same size as the spark plug post) so I put the Spark tester in line with the plugs and it is all hooked up. I crank the motor and the light blinks on every rotation of the engine(which indicates spark) So I am pretty confident I have spark. So I hook everything up put the ignition housing cover back on and get all my fuel lines run and carb on and fuel her up. I crank her over and no start. I check for spark again and I still have the light. Try to start it again .....nothing. So I take out a plug and hold it against the engine and crank....no spark on the plug even though my light is telling me I have spark. No I have new boots and I trimmed the wire about a 1/4 of an inch. I am confused because something is telling that light to light and that usually indicates voltage . Now on a hunch I pulled the lanyard off where there should be no spark. I crank it and the light is lighting like it should be sparking. I am stumped. It is obviosly electrical but I don't know where to start. Where would you guys start? cdi? coil? stator? Flywheel, Electrical box? Help!!! I am so close to getting theses things in the water. I also have a 90 SP which I did all the same thing to I basically restored both boats so I am ready to dunk the 90 in the water it starts and runs but now the 89 is breaking my balls with the spark. Please help and give me a place to start.
oh the one thing I am hoping for is this, when I went to buy plugs for it, I asked for NGK BR7ES all they had waas B7ES the guy told me the "R" was for resistor and it only had to do with electronics interference. I do have the correct plugs in now but I had the other ones in for this testing.
