Hi all,
I recently cracked a rave valve due to the cap melting. I figured the engine probably got hot. I dont see much smoke coming from my ski, like my friends. I am concernd the pump isnt working properly. I have been reading about removing the oil pump. I have made up my mind the oil pump will stay. I just want to make sure it is working the way it should. I put a new filter and 3/16" lines on it. The only way I can see oil moving is when I move the lever all the way open. There is a small air bubble in 1 line, when idoling the bubble never moves. I also have air in the new filter I cant seem to get rid of with the bleed. I have put oil in the gas to make sure the bubbles wont hurt anything. Can someone give me an idea if this sounds ok or should I try something else.
