The boat is a '99 Challenger 1800 with two 787 engines. I'm just about ready to start her up after a full rebuild of almost all the systems and have two questions:
1 - I replaced one engine and rebuilt the top end of the other. I removed the oil pump and plastic drive from the replaced engine, but is there a way to remove the plastic drive from the other engine with it installed? I don't think I can slide the plastic drive out the opening. I don't want to remove the whole cover, but that might be the only way.
Anyone leave it in there and just put the cover on? (Doesn't seem like a good idea) How about leaving the pump there disconnected? Will the pump overheat w/o a flow of oil?
2 - How much oil do you put in the balance shaft case? I looked in the manual, but can't find anything. One picture shows 1oz of oil, but I'm not sure it's pointing to the case (page 04-06-2). Also, what oil to you use?
Thanks! Hope to have her running again soon!
