brobertov8
I have read some threads about many fails in these two oil pressure sensors on 4 tec engines.
Does this really occurs often?
Are these two codes the correct part numbers?
420256777 (to the block of the engine) and 420256885 (near to the oil cap)?
One of the thread I´ve read says:
"MANY Sea-Doo 4-TEC & SC 4-TEC engines are effected by bad oil pressure sensors. Sea-Doo does NOT have a good part at this time, and some are not being covered under warranty. Right now the parts are lasting several months before going bad again. The good news is, the part is only $20 and takes just a couple minutes to change.
Symtoms:
The Check Engine light will come on. Power will be decresed. Top RPMs will be down a couple hundred. Out of the hole performance is very lacking, similar to the learning key. Removing and replacing the lanyard will restore performance for a few seconds to a few minutes."
Is that correct?
Thanks
Symtoms:
Is that correct?
Thanks
