OIL leaking into bottom of the ski
ggm
Hiya all
I wonder if anyone could help me please
i have a GTX supercharged 2003 with 66 hours from new.
Supercharger stopped working, gave it to seadoo engineers, he removed supercharger and luckly enough i have the pre-mod, now washers. so repaired the supercharger and all is fine.?? supercharger and engine now running fine... but
I now losing oil into the bottomn of the ski and cant find were its coming from,
run ski for 5 mins no issues, go back out for say 5-10 min and oil in bottom of ski. used about 1/2 liter in 15 mins, oil runs out of back of ski.
help please
Graham
Did you call the dealer?
If it's leaking where they took it apart then they are responsible to fix it.
I know exactly what that is... It's the seal on the drive shaft... The o ring seal has gone bad. Had the same thing happen. Sorry don't know the name of that seal.
could also be the sc seal, if they rebuilt it and damaged the two o-rings and didn't replace them properly, it will leak oil. put your hand under where the sc goes into the pto housing to check.
guys for feedback
im sure it had a very small leak before the sc was rebuilt, i did put my hand right under the sc to see if its leaking out to the bottom, could not feel anything,
how can i check to see if the seal on the shaft is duff? would it lose 1/2 liter in 10-15 mins or even more oil.
