I have a 1997 GTS which is leaking oil from the engine. I have thoroughly cleaned the engine and hull with an automotive engine cleaner and even added a dye to the oil tank to help identify where the oil is coming from. It is not coming from the tank or lines. All tank grommets have been replaced. I have removed the large oil lines, cut off the ends and re installed them. It is not coming from the injection system on the carb.
I can see oil on the black steel cradle which supports the engine but it just serves to collect the oil since it has a curved shape so the oil runs on it into a pool. The engine was replaced a couple of years ago by a dealer who is knowledgeable and did good work.
The leak is happening even when the engine is not running.
Anyone have any further suggestions?
Dave p
Dave p
