Hi all new to the forum but hopefully someone can point me in the right direction
To give you a mental picture to work from, I pulled the engine down 5 years ago “long story as to why it took so long” but it was due to a failed small end bearing in my 587 white motor single carb from Seadoo GTS 94
I have finally rebuilt it and put it back in the hull but when I filled the oil reservoir I started to get oil running from the water inlet beside the jet drive now I’m pretty sure I put everything back as it was and following the manual but after 5 years the memory is a bit foggy ?? I checked the oil piping etc was all in the right place but I’m thinking I must have missed something inside the motor for oil to be crossing from the rotary valve feed into the Coolant galleries any thoughts on what I might have done wrong ? Obviously haven’t run it yet ps I went with the original seals in the middle of the crank but fitted a new rotary shaft assembly tested the oil pump was functioning on the bench as per the manual any advice would be appreciated as I’m not keen to pull it all back out unless I know what I’m looking for
