Thank you for the info sportster. To run a compression check do I need a special compression checker and is there a way I can manually crank the motor? Also would you happen to know the specs for the amount of psi they need to have ? Thank you for your help.
I believe that motor typically blows north of 150psi (150~155psi?), maybe someone who has one can verify that detail. You can get a good quality compression gauge in many autoparts stores, look for one with a gauge head that comes with a hose to attach(screw) into the spark plug threaded hole during the test. These gauges typically can measure over 300psi, so the needle should read about half scale (~150psi). Also important is cylinder balance, I like to see a reading within 5psi of each other would be ideal, greater than a 10% variation between cylinders is outside of reasonable and indicative of a problem. I like to do the compression test at least once per year, normally at the end of the riding season.
Some important notes on preparing for the test:
Shut off the fuel supply valve, you don't need fuel during the test as the engine will not be running and fuel presents a fire hazard.
Make sure to locate the three sparkplug wire grounding posts and always place the plug wire ends on them while cranking the engine using the electric starter, or else damage to the ignition coils may occur. This also reduces the risk of fire and ignition of fuel vapors that may be trapped in the ski's hull.
Hold the throttle lever wide open while cranking the engine to build cylinder pressure, holding the throttle lever fully open shuts off the fuel injectors by safety interlock, this feature is otherwise known as fuel-flooded clearing mode. Remove all three spark plugs before beginning the cranking test.
Record your readings, I often write them directly on the cylinder head using a permanent marker.
Also, here's an generic article describing the process:
http://www.popularmechanics.com/car...ars-101-how-to-do-a-compression-test-14912158
