ok i was just woundering on my 1993 Seadoo SP the oil goes into the bottom inlet fitting and then it fills up the case and then it goes out of the oulet fitting bellow the exhaust ports of the engine. Then the outlet fitting hose runs to the top of the oil tank and drains into the tank.i was wndering does the oil that drains into the oil tank from the top have to drain constantly or do it just pump out when the crank is turned/egine started?? Because the oil doesnt drain constantly in my hose it will just sit a little more than half way up the hose and it will not drain constantly..Do you think its is because of the postion of the hose or is it something else???? Thanks
