Oil change problem
rippinron318
I have a 2008 seadoo rxp215 and ran into a problem while doing and oil change. I had to small hoses connected together and one of them is now stuck down the dipstick tube and cannot get it out. Wondering what the easiest way to solve this problem is. Thanks!!
Surprisingly, the dipstick tube just pulls out.
It has 2 O-rings in it and his held in with just pressure.
Pull up on it with some force and it will pop off.
Hopefully that will be enough to expose the tube.
It doesn't just pull out. It is clipped into the intake manifold and will not come out without doing major damage. Unbolt the 7 bolts for the intake manifold and rock it away from the head and inch or so. Then push the tube towards the head to unclip it. Now it will pull out.
