mostlyharmless
I purchased a 1996 GTX and had tole address some basic electrical issues and replace some components. After ski did the double beep thing I go to turn over and she won't crank while the plugs are in. I took the plugs out today to see if it was a battery or drain issue.
As I was turning over the engine after removing the plugs, an oil and water milkshake spatter was spraying from the plug holes. It must be causing a hydro lock condition while the plugs are installed that keeps it from fullyta turning over.
My question is...
The Ski has been out of the water for some time and wasn't used this past season, so where is the water coming from?
Also, if it is oil injected, and wasn't used last season, why do I get milkshake when I turn it over now?
Could there be water in the exhaust system that is backing up into the cylinders and mixing with the oil that is getting injected while I am turning it over? Could the fuel be contaminated with water and while I am turning it over the milkshake and hydro lock is what is occurring?
I was going to check the fuel tank tommorow for contamination and clean and prime the fuel tank and lines up to the carburetors if that is the case, then continue to crank with out the sparkplugs installed to see if it clears out the milkshake.
Does anyone have any ideas as to the correct way to move forward, or if there could be more damage or cleaning out that would need to be addressed before I try to start it?
Any advice or suggestions would be appreciated as I am a noob and could use all the help I can get.
My question is...
