Oetiker clamp diameter
nhmort
I have a 2000 Seadoo GTX DI.
I'm going to replace the fuel filter with the suggested modification to the automotive one.
Does anyone know the size of the Oetiker clamp? Is it 17mm?
My ski is at my cabin a few hours away, so I can't measure them.
Thanks
What fuel filter will you be using? I'm not that familiar with a DI ski but the lines on a DI ski are high pressure so unless the filter is before the fuel pump you should probably use OEM or at least an all steel filter.
The clamp size should be on the parts diagram or the service manual.
Lou
I'm going to use the steel one that Doowacka said that others were using.
I've got the Seadoo parts manual, it just says the part number but not the size.
Thanks
