TomShadow Member Jul 31, 2018 #1 So a friend of mine bought a cheap 98 GS (white) 720 I think. Tested compression and the front cylinder had maybe 10psi, the back cylinder had 130. Where should we start?
mikidymac Moderator Staff member Moderator Jul 31, 2018 #4 Yes, if it is that much lower you have mechanical damage.
mikidymac Moderator Staff member Moderator Aug 2, 2018 #6 Pretty much expected with those compression numbers. Crank is probably trash now too.
Mekanix Premium Member Premium Member Aug 3, 2018 #8 Yup. Not just a top end. All that debris is in the base now and could have damaged the bearings.
