matthechat
I've been having a lot of trouble with this ski. It was fouling plugs so I cleaned the carbs and adjusted them to spec and it ran a lot better...but it was really hard to start so i checked the rotary valve clearance (.014") it's within spec but it has some small grooves in it. I put it back together it started backfiring at over 5k rpm on the water so i took it back apart and checked/adjusted the rotary valve, took it back out and it would start but wouldn't plane off because of backfiring. So i pulled the plugs and put my thumb over the holes and cranked it. Plenty of compression in the rear cylinder, none in the front...is it possible that the exhaust valve is stuck open or is that even possible? I thought i'd ask before tearing into it looking for a broken ring or a hole in the piston haha. Compression was 145 in both cylinders a couple weeks ago.... Thanks!
