You can obtain a year-model SHOP MANUAL and learn everything about your ski.
You can click on the link seadoowarehouse to veiw your skis parts and part numbers.
then at right top click "parts by year, then by Model, then Section, place a number
in box at left, scroll down to page bottom and click Add items to cart, and then the
parts numbers will appear! then click the Clear Cart button after you obtain the #
or you can order that part from our host! Your SHOP MANUAL will describe in detail
how to maintain any part or remove and replace any part on your ski.
NEW MEMBERS ARE ENCOURAGED TO JOIN AS PREMIUM MEMBERS
SO AS TO HAVE ACCESS TO THE FORUM LIBRARY AND SUPPORT!
Please also to use the SEARCH function, as many subject questions have been
already asked and answers many times!
Beeper/buzzer is inside the handlebar pad where it can easily be heard. The wires
are loomed down the center of the steering column then connect to the electrical
wireing harness. A DETENT TOOL is available from Radio Shack for pushing the pins
out of the plastic connector clip if you desire to pull the wires thru the column. Note
each wires orientation if you do that. Some people just connect a new beeper under
the sterring consul as a easy location. Hope this Helps! Bills86e
