I can recommend a few fun mods that are easy and pump gas friendly....
1. Higher compression head with no more than 175 lbs. per cylinder. You can buy a nice aftermarket head(BuckShot, NOVI etc.) with 43cc domes for 91/92 octane pump gas. Or you can have the OEM head shaved down to increase compression that way. I like the aftermarket head with more cooling capabilities due to the higher heat generated with the increased pressure and the good looks of an anodized head/head shell
2. Free flowing flame arrestors(K&N, R&D, ProK, Tau Ceti/Hot Products) will allow the engine to take in more air. A step up with the Pilot Jet from 70(stock) to a 75 is required for proper jetting with this mod to avoid engine damage(lean condition)
3. Aftermarket sponsons that are adjustable make for some great handling in long sweeper turns, rough water handling and just keeps the ski from sliding out and sending you into a tail spin. Lose the stock sponsons for great handling. Just be aware that removing and installing the stock and aftermarket sponsons like WORX Racing sponsons require silicone around the bolt holes and aren't too much fun to remove and install. But once they're installed. You'll have a blast with carving and being able to hold turns very easily without sliding out
4. Trigger throttles are way more comfy than the stock thumb throttle. U.M.I., GT or similar brands are great additions to your ski for riding comfort.
5. Gunwale mats like Hydro-Turf(Anaheim, Ca.) mats are another great addition to comfort(shock absorption and traction) due to the closed cell foam design will give you traction while turning, jumping and reboarding. As well as great looks with different styles of colors, camouflage and marbling to suit your fancy. A must have in my book
6. Intake grates help keep the pump loaded with water for forward propulsion in rough/choppy water. A top loader intake grate from R&D or WORX work really well and are very popular.
7. Custom seat covers add a nice touch to your ski. As well as traction, longevity of the better materials and custom stitch work like from JETTRIM(Lake Havasu, AZ) pull it all together
8. Stainless steel impeller(s) from Skat Trak or Solas add speed, torque and midrange power, depending on the pitch of the impeller to match the power enhancements of the engine. You already have a 17/22. So with any other engine mods. You could play around with different pitched impellers to get the desired power output
9. R&D Exit/Steering nozzles are a very nice addition. Since it can add speed(smaller diameters than stock nozzle diameters), torque(larger openings than stock diameter) and handling(nozzles are physically longer than stock nozzles). They are tough to find a set in the right diameter combo for your set up. But they are worth the hunt. The 85mm exit & 88mm steering combo is the most popular.
There are other modifications that can obviously be done and will cost more. with possible higher maintenance. But will make the ski go faster and behave differently. But the items I've listed are all of the items I used on my '96 Sea Doo GSX when I first bought it in Aug. 1996. I gained low end torque, handling, better acceleration and the fun factor was much improved over stock. It is a very reliable set up and not too expensive to put together. You could install all of the items yourself with minimal tuning of the carbs due to the flame arrestor(s) and higher compression head.
