Hello,
after take out the engine to check why the oil is contaminated with water, I'm want to replace the most important parts like exhaust valves, flywheel bolts... But first I need to know what parts are the most problematic on this model.
This is 2005 model, so I will start with valves: I will replace all valves (exhaust and intake) with a supertech valves. Is a good option? I only replace valves with keepers (no springs replace). Any better suggestion about this? And do you think that is good idea replace valve seals? Or can I reuse it?
Also I will check oil pumps. If it is on tolerance, it's not necessary replace this parts?
And what about crankshaft and rod bearings? The engine have 200 hours. Do you think that is necessary to replace this bearings? If I remove the crankshaft cover, I must to replace the bearings or can I reuse it? And bolts? I have took out the engine because there are water on oil (you can see this here: RXT with water on oil
Also, I looking for a full gasket kit (aftermarket) without head gasket (I want to buy an OEM). Can you suggest any gasket kit? With valves seals or not?
Thanks!
Edgard
Thanks!
Edgard
