JJinSC
I just had my oil injector pump replaced a few weeks ago because of the nipple coming out of the original. After cleaning the oil out of my hull, I noticed more oil after a ride the other day. Thinking I had not left enough room for expansion when I topped the tank off after the previous ride and it leaked out the check valve at the tank. I sopped up the oil in the hull. Before the next ride, I peaked in the hull to make sure no oil had leaked. It had not. When I returned from the ride, I checked again and there was some oil right around the syphoners. Not a lot, just a little. I inspected the hose feeding the pump and it seemed to have loose oil on it. The tech that installed it used a factory type oetiker clamp and the connection looks good.
Where could this oil be coming from and is this something I should worry about?
