Hi guys,
Just got a couple 95 SPX models from a friend who wanted out from under them. Basically I'm $600 in on this deal and it included a galvanized trailer, so pretty happy thus far. Both have some gouging in the hull, and between my neighbor being a fiberglass guy and a recommendation to contact Gelcote for the gel coat, I think that it handled. One has a blown engine; the head is off and there are chunks of piston everywhere. That will be my donor for the 'good' one. Right now the goal is to get the good one in the water and run it this summer.
I have a few amateur questions and am hoping you guys will oblige.
1. The hose that goes to the coolant bypass exit port, near the front on the starboard...that isn't hooked up to anything on the engine side and there are no obvious candidates for where it goes. Anyone know where I should be looking? (Edit: looks like a battery overflow line)
2. The 2 electrical prongs on the front of the engine next to the electrical connection and just behind the battery...what are they used for? (Edit: Apparently for plug wires)
3. Is there a way to clean up the rear grab handle without the material pilling up and coming off?
4. The handlebar cover is toast, it literally broke apart as it came off. Is there a kit to give this thing more of a MX/simplified configuration?
5. I have yet to see any convenient drains for the fuel and oil tanks. Do I look harder or use a transfer pump? (Edit: found a bottom port for oil, not fuel, guess transfer pump for this one)
If you guys see anything else in the pictures that looks sketchy, I'd sure appreciate you calling it out.
Thanks fellas!
Thanks fellas!
