I would think if you bought a fuel injected rated fuel line the same length as the one that’s on there and bought 2 of the part 25, two of the part 2, on the parts fiche, cut the new line, crimp a brass T fitting, fuel line up from the T to a fuel gauge. Fuel injection clamps should work on the brass T and on the gauge. Part 2 on the fiche is Connector PN 275500428 and part 25 on fiche is connector stopper 275500429.You’re welcome, I’m interested to see how it turns out, let me know which parts you end up using.Thanks very much for the info Burt much appreciated!
I will thanksYou’re welcome, I’m interested to see how it turns out, let me know which parts you end up using.
Looks good, will you be able to see the fuel gauge while driving?I made a working guage , listed here are all the pictures with part listings below.
Here is the finished guage
How its attached
Engine running showing 60 lbs PSI
Here are all the parts
MeasureMan Guage
MeasureMan Guage Female Brass Connector
T Barbed Fitting
Quick Connect Male Fuel Rail Connector
Dorman Straight Line Fuel Adapter 2 in a pack
Single Ear Hose Clamps (optional can use regular hose clamps)
And get 1 ft of fuel line - I used 5/16
