Need some advise - Rebuilding a 99 GTX-L
I went with SBT, and so far , 10 hours in on my new motor , runs like a stuck pig! and i beat the piss outta it too!
Ok, the cylinder and RAVE valves are on their way to FullBore and the crank just showed up from SHS. It looks really nice. The next question I have is about rebuilding the RAVE valves. There was a considerable amount of oil under the plastic cap and I don't think there should be any oil there if I understand the system correctly. What parts do I need to order to rebuild them? I see an o-ring on the valve itself and a diagram mounted to the end of the valve. Anything else I need to replace?
i'm the same way as sqrl... just clean them up, and reinstall, but you can order rebuild kits with new diaphragms and stuff if you want, i think sbt has them.
