Need rear styrofoam hull inserts for a 97 GSX
sselzer
I'm in need for a cheap set of replacement rear styrofoam hull inserts for a 97 GSX. The previous owner hacked them up upgrading the sponsons. Here's a picture of where one of them should go .
Ask [MENTION=41828]Minnetonka4me[/MENTION] if it is the same as a 96 gsx because I am going to be crushing one in a week or so. So I may be able to save it.
I have a '96 GSX and a '97 GSX and they sure look the same to me. Well one is red and one is blue ... :)
I know you have a red one. I am crushing a 96. If the foam was the same I was going to save it for you. I have no clue if the foam or the if the hull slightly changed between the 2 years. Maybe you can do some homework and see if it fits. I have no idea how you would replace it though. At the factory they place bags under the solid foam pieces then inflate the bag with a spray foam to lodge it in place.
I know you have a red one. I am Whscrushing a 96. If the foam was the same I was going to save it for you. I have no clue if the foam or the if the hull slightly changed between the 2 years. Maybe you can do some homework and see if it fits. I have no idea how you would replace it though. At the factory they place bags under the solid foam pieces then inflate the bag with a spray foam to lodge it in place.
I need both side for my rear, there aren't any inflated bags.
What are you asking for them and shipping to 34606 Springhill florida?.
Lets not get ahead of ourselves yet. Let me break down the hull. I crush it with a bobcat. Sometimes I split the hull perfectly and the foam stays intact. Other times it breaks into a ton of peices.
