C2260: the iS system under voltage, check battery and charging system.
C2221: Unexpected battery power lost or memory failure. Ignore fault if "occurred". States to check: Verify starting and charging system circuits.
Clear fault Refer to the service manual for more details.
C2161: Battery failure, rectifier failure, damaged circuit wires, battery terminal connection, damaged AC generator or damaged connectors. Ignore fault if "occurred" States t check the following: Check fuses #6 (REFER TO WIRING DIAGRAM). Check ground continuity to the engine block. Refer to the service manual for more details
In a nut shell, I am betting you have a bad battery. I had 11 IBR codes and after plugging my CanDoo Pro into it, every code had to do with low voltage to the IBR system. And yet,,, the battery was good enough to start the ski. I went and bought a high end acid battery and all is wonderful...
