need help setting carb
nickvolvo40
i know the low speed setting is suppose to be from all the way in 1.5 half turns thats full revolution correct
and can someone tell me how many clicks the high speed screw is suppose to be set at it was set all the way to left which im assuming is wide open i see all over the forum its says 0 is this all the way closed by the way its a 2002 gti
seated
I'm double checking, so the high speed on may Sea doo's say 0 Zero... is this fully seated? Mine doesn't have plastic caps so I should fully seat them or have them a bit open?
if this is the case Why do they have high's if they are fully seated?
thanks
