hey guys,new to site.....got a problem,after running ski for a while(which runs great for as long as you ride without stopping),when you stop and sit on a warm engine,it will not crank back up.what i've been doing to get it going is remove plugs,squirt mix gas in plug holes,replace plugs,and crank.at this point,it may or may not stay running.either it will idle,but as soon as you give it throttle,it dies.or it may surge and then ease off until it soon takes off then runs great(until next stop).i've noticed that in some cases,that if i remove the return fuel line,it will start,then shut down.its not fowling plugs or running bad gas.i've been told that it may be carbs,vents or stuck choke.help guys! im lost on this one......
