waterdog15
Hello All,
I have an interesting series of questions. I have a 2005 Seadoo GTX. When my jet ski wouldn't start, I noticed the company who performed the winterization had left the spark plugs disconnected and also the #2 spark plug insert was about an inch from being seated. When it was removed, you could see rounded indentions in the chamber the spark plug goes in (imagine what looks like 3 blisters). If the stamped cylinder identification is 12 o'clock, the blisters are located from noon to 4 o'clock. Although I don't think it is related, the top of the spark plug (the threaded end) is bent. There is no way to get the plug out with the cylinder wall the way it is. The plugs haven't been changed since I owned the ski (the winterizing company was going to do it until they saw the blisters)
I bought the ski used from a local dealer 2-3 years ago. When I test drove the ski, it would go accelerate awesome but would not go above ~35/40. The dealer said it was due to a wear ring needing replacing. They fixed the wear ring and I bought the ski. The ski ran 70+ mph then and as of last year ran 70+ mph.
Any idea as to the cause of the blisters? By the rounded nature, I am guessing possibly the "chamber" behind it was over pressurized?? What is behind this area?
Due to the bent spark plug tip and the "wear ring", I am wondering if I was taken advantaged of. I am thinking it was actually running on 2 cylinders vs. 3 cylinders. What are the signs of this? And what are the signs of a bad wear ring?
Thanks for any help,
~Waterdog
~Waterdog
