Hello. I just acquired a 1995 Speedster. The previous owner had had the oil injector lines replaced on the starboard engine, but they badly need to be replaced on th port engine.
I would appreciate any advice or insight into the process that any of the members of this forum can provide, including the best way to access the pump and fittings in the very tight space under the carbs. I have removed the breather cover, but it is still tight. Additionally, the current lines are crimped onto the fittings at either end, so if you have a good suggestion as to how to remove those, I would appreciate th advice.
Finally, I would be interested to know your experiences with bleeding the lines once they are reconnected.
Thanks in advance for any and all help!
