TheYeti
Well I have a previous thread from awhile back where basically I had redone the carbs over the winter and then took it out for the first  test drive of the season and I could throttle up and not move very quickly then I ended up replacing the wear ring hoping that was the only damage.  Took it back out for another test amd after the boat stalled out I found I was taking on water.  Towed back to the dock and brought it back home.  Took spark plugs out and repeatedly started to get water/fuel/oil mix out of motor.  I beleive it was mostly water.  Now boat wont start.  The starter will some times act like its hydrolocked so not sure if its actually the starter now too but even when Im able to crank it, it wont fire.  I've removed and dried plugs multiple tiles while trying.  I gave up feeling defeated again today.  To top it all off the bilge pump will work in the driveway (after initially blowing it out with air compressor)  but anytime its been on the lake it conelveneintly doesnt work.
At first I had thought maybe I had enough water in the hull that day it sucked in to the carbs but I'm now not thinking there was that much water to get to that height BUT maybe it was high enough to affect the starter(?) I really don't know for sure. I am guessing I need a carbon seal now too? But want to get this thing started so it can be winterized asap before spending any money on fixing driveability issues. Before this last trip the motpr started and ran right away and compression test was good.
In case your curious here is one of the old threads... Any suggestions? At all? I really should get this running asap before winter here to winterize at least. Really need spme help on this one...
Throttle up and no go...?
