My boat is finally done... what should I look for?
cheappc
They finally rebuilt my engine..
My boat is finally ready, what do you guys think I should look for?
compression test?
If it was done at a reputable shop... just go ride it.
But, if it was me, I would double check for oil, and water leaks, and after the first tank of fuel... check the compression, and put in a fresh set of plugs.
Tony you know I always listen to you!
It is a reputable shop, but Im still going to do what you said to do!
I would pre mix to make sure oil injection works right..
Glad your back on the water.
Thanks guys! I will do the compression test.. Im glad im back on the water..
Summer is about over.. but oh well...
If I were checkingfor oil I would take the oil line off and turn the engine over to see if oil came out. Is that how you guys would check it?
