Ok i have a 94 XP 657x, i purchased it not running, has new motor ran good for one year then something happen to the timing according to the previous owner. so i began working and checking everything. 130psi compression, good plugs good fuel. finally got it to run by turning the flywheel 90 degrees and removing the woodruff key. but my battery is not charging so i ordered new stator and charging coil. same results and i even tried putting the flywheel in correctly. but the jet ski will only run with the flywheel turned 90 degrees and it wont charge the battery. please help i am completely depleted here, out of ideas and am losing hope in everything.
