mkov608
Greatings everyone! I just replaced my MPEM (2002 GTX) since the fwd AMP connector socket had a loose connection with the Motherboard. I would wiggle the connector with the key on the DESS post and the ski would intermittently power up. I swapped MPEMs between the SKIs, and the problem followed the MPEM.
I found a used MPEM on Ebay with the same part number, but it came out of an '05 ski. I just installed it, and the ski fired right up. My question is, why did Sea-Doo go from a simple 2 beeps with the key on the post to 2 beeps and then another 4 rapid beeps? I pulled down the '05 manual, and it says the 4 rapid beeps is to let you know you left your key on the post and that the 2 beeps tells you (1) the lanyard signal is working, (2) the ECU recognizes the lanyard, and (3) there is good contact with the DESS post. On the '02 ski, you hear 2 beeps for all of those functions. Here's the section from the '02 manual.
Here is the difference in the '05 manual. It was also curious both MPEMs have the same part number.
