Motor mounts.
Gingi017
Hello all , I was recently gifted a 2014 gtx and I’m wondering if there’s anyone that could let me know if the motor mounts line up with a 230 and if it can be swapped. I believe it was a 155
Yes, it will bolt up but it is not a simple conversion. They use a different pump/driveshaft but can be converted with some machining.
It would be way easier and cheaper to swap in a 260. Most people doing the 4tec to ACE conversion are swapping the 300. Haven't seen anyone do a 230, probably because it is way too much work when it would be simple to do a 215 or 260.
