brandon32689
hey guys i am going to be putting the motor back in my xp thursday or friday, just going to do a rundown and make sure i got everything please add if i dont
Engine
seadoo alignment tool
shims
wear ring
impellor remove tool
exhaust gaskets
block off plate
oring for the jet pump cone
i know i need coper sealent for the exhaust, but anything else? i am having to switch to block off plate, i think that had something to do with the motor blowing in the first place, spun the pump with a drill and the oil hooked up and nothing eever came out.... that being all said, what gear oil can i use locally for the jet pump and do i use some type of sealent when putting the jet pump back againts the hull... thanks in advance guys, this is my first time doing all this so hoping it comes out good.
Engine
shims
wear ring
exhaust gaskets
block off plate
