shockerfd
I figured I would start a new thread on my boat issue. Today my father-in-law and I pulled the carbs apart. He is a engine guru of all sorts, especially with carbs. We found the diaphram on the MAG side to be warped. (thanks Seadoo dealer...they weren't that way when they went to you) Being warped, there was no movement allowed from the spring and float. Got that straight and richened up the low and high speed a little more just to be safe. Boat runs better but still bogged a little on the low end. Plugs were equally black! Awesome. At least I know they are getting fuel. Might have to dial back the low and high speed. Ran low on fuel and switched to reserve and boat wouldn't run. Was getting dark so loaded up and headed back home.
1. Get home and find MAG side rave valve was leaking oil from the top of it. These are brand new. What can be going on here?
2. Boat will not pull fuel on reserve switch. I connected the fuel line to the carbs to the reserve connection on tank baffle and boat started fine. My question is, "why won't my boat run on reserve"?
I think I'm making some headway with the carbs but the leaking rave ralve has me concerned.
As always guys...thanks!
