VERDUGO135
Took my 08 speedster 200 out today for the 1st time and about 3-5min in the water while still in neutral the starboard temp light came on. I pulled the boat out and called a mechanic friend. He said I should check water pump or thermo.
Anyways I realized the right side heat exchanger (radiator) is not getting as hot so mechanic is probably right. Is the water pump just an impeller or do I have to get the whole housing? Thanks in advance.
