Have a customer that needs a set of cases (matched sets only). Front piston took a dump and cracked the cases. Let me know if anyone of you have any. Thanks.
I was working on an 04 GTi the other day and I had a close look at the cases. You can just take the rear mount brackets off and install them onto the white cases after removing the studs for the wing nuts on the PTO cover. The front brackets are not an issue as they are on the Flywheel housing.
