Michael211_2000
Yesterday when starting my RXT at the lake I noticed for just a second or two while the starter is engaged I'm getting a "low-vlt" warning message scrolling across my display... it goes away just as soon as the engine starts though. My battery is not quite 3 years old and I keep it charged with a Battery Tender Jr thru the winter months when I'm not using the RXT... the RXT had sat since the 1st of July till yesterday without the battery being charged nor engine run, I've been busy with work and buying a Spyder so yesterday was my 2nd outting with the RXT this year.
I put the battery on my Battery Tender Jr. when I got home yesterday, and before bed last night I checked and the tender light had turned solid green so I took it off. Today I pulled the battery out and took it to be tested at Walmart Automotive 1st.... their computer said the battery had full cranking amps but low voltage and the recomendation was to charge the battery. Huh? Why would it be low after I'd just charged it to full with the tender the previous evening?
I then took the battery to the auto parts store where I bought it in October 2010 and had them test it... their machine 1st charged the battery up to full charge (took it 15 minutes) then load tested the battery and pronounced it "Good".
So, I'm not sure what's going on here... is something draining my battery that fast when it's connected to the RXT? Or is the battery really not so "good" anymore? I presume if the RXT's charging system wasn't working it would have a warning message on the display all the time right?
Thoughts?
Thanks!
- Michael
Thoughts?
Thanks!
- Michael
