low compression, where from here
pull the rear cylinder, if looks good, and piston looks good, have the cylinder honed, and install new rings, just to get you thru the season.
collapsed/stuck rings on pistons, diveted piston top, scratches on side of piston and walss of cylinder..aka sleeve.
$260 gets you a top end rebuild if you can do the work yourself....google "787 top end rebuild"
