Lost screw in hull
Chris0412
I dropped the screw that you use to reconnect the battery which is no problem I got another screw and jetski started right up. My issue is I can’t find the screw inside the hull will it do any damage I don’t wanna go crazy looking for it
You mean the screw that connects the cable? When I replaced my battery, I did the same thing. Had to remove the battery and the housing. There were 3 "lost" screws under the housing - been there for years. Don't worry about it and keep extras on hand for the next time you drop one.
i have a 13mm socket that is lost in the hull of my xp. along with a couple other screws (yes, i replaced them all). you'll be fine.
