sniper-ghosts
Hi, I'm new here and read some post on engine compression here. But nothing comes up on this situation.
I'm really stuck on solving this problem with my rxt300 2016
Below is the situation.
Rxt 300 2016
225 hours, mostly trolling hours
Runs and starts like new every time.
I never ever had any problems with it and I looked after it every time. So it's in excellent condition inside and out
Took it for a it's yearly service and the mechanic said it has a low compression reading and needs to be rebuilt. Around 8 to 12k
Front 48 psi
Mid 60psi
Back 65psi
I took it out 6 times after this to test it and still runs like new and starts first go. You would think it came from the shop new.
Did another compression and it's the same.
I had 2x people 200kg of weight on it today and run 116km in sports and normal mode no problem at all.
If it has low compression how can I get to this power and speed?
My heads hurting from all the research so if anyone has an idea to fix it and not just do a rebuild because it's reading low.
Thanks in advance.
Rxt 300 2016
Front 48 psi
Mid 60psi
Back 65psi
Thanks in advance.
