Leaking 2005 Seadoo Sporster LE DI
etemplet
Moderator
Moderator
Premium Member
We found a really bad leak on the BACK RUB RAIL on the ski step. For the test we left they tie downs in place and backed down the launch ramp. No leaks until we got the back section under water. As we went further and copious amounts of water poured in. Not being familiar with the boats is this a common issue with leaks through the back rub rail?? It wasn't as big an issue after we removed the tie downs and launched normally but water still leaked in. Is this normal?? The boat doesn't look like it has been repaired. Anyway to me... this area should be sealed up tight as in NO LEAKS. Help input is appreciated.
