heavenlyride
Have a leak when sitting in water. It is almost that time again. Want to get a jump on this.
I had the carbon seal replaced. So not that.
I have been told to look at sponsons on the side, but not what to look for. Do they have grommets that need to be replaced? Is there another reason they leak?
Drainage plugs were another point to look at. Is that to replace the unit, a washer or a seal with silicone around the inside of the hull?
What about the flush port? Can it leak into the hull? I want is the fix?
Thank you in advance, trying to get a jump on it and fix it before the season arrives.
Elliott
Elliott
