uraceulose
New forum member here and loving this place!! Will look into the benefits of premium membership when I get home later this week.
20+ gallons is a lot to pre-mix over and over in my opinion. We just purchased a 1997 Speedster on Craiglist. It is my/our first boat and I'd like to maintain it from this point forward as much as possible.
The previous owner told me that he pre-mixed the fuel at 50:1 and just left the oil tank empty and didn't worry about the red light. I prefer to use the system the way it was intended if at all possible.
Is there anything I can change as far as filters or anything need to be "primed"?
I was thinking to just run the tank down real low on fuel then pour in a couple gallons of oil and fill up the tank with fresh gasoline. Might foul a set of plugs?
Is there anything else I'm missing? I was also going to look into the wear on the impeller ring and wanted to find out about fuel/air/oil filters? Where do I measure on the impeller wear ring?
Is there an air filter or fuel filter to change?
Thanks so much,
Donnie
Thanks so much,
Donnie
