CinciRides
So I tore apart my jet pump and discovered that the ring behind the jet pump housing was shredded. The rubber seal is fine but hard plastic ring came in contact with the impeller and got tore up (I had plastic bits shoot out the back of the pump). I also discovered that the previous owner did not maintain the cone and it has been without oil for years. So my question is: If that plastic ring still sits into the wear ring gap nicely and the rubber seal is good, do I need to replace the plastic ring?
I'll post pics in a bit...thanks!
