yabbah Member Sep 26, 2019 #1 As the topic say, does it show the water temperature on the garmin or somewhere else? /yabbah
joe.burns91 Active Member Jul 23, 2020 #2 The garmin won't know because the transducer is in-hull. Not sure if the ski will tell you water temp elsewhere.
X xspook Active Member Jul 27, 2020 #3 Water temp is available on the gauge (not the GPS) for the 2020 Fishpro.
B bryce600rr New Member Jul 28, 2020 #4 xspook said: Water temp is available on the gauge (not the GPS) for the 2020 Fishpro. Click to expand... Yes this is correct!!! The Garmin will not show water temp due to the transducer being mounted in the hull but the dash cluster does show the water temp and from what i can tell it is very accurate..
