No, that impeller is generally not OK, nor is the apparent gap between the impeller and wear ring in the lower right of the photo. You could keep running it, but your performance would not be optimal.
You should benefit from an impeller recondition or new impeller, and new wear ring. Both holeshot and top end should be improved.
Someone else who knows this boat may also have some advice on that intake grate as well, it looks like those tines are suseptible to breakage?
